Accurate Reversals with Encoder
The enclosed VI is for  reversing a Servo Drive based on angle feedback from an Encoder. Being a simple state machine, no elaboration is required.
The problem however  is the accuracy of reversals. Assuming that drive is rotatting at 60rpm, it will be  1 revolution or  360 deg per second. Or  0.36 deg per millisecond. My loop timing ( intervals between  each poll of the encoder feedback )  is 25ms. ( I cannot reduce this due to some other issues ).
Thus the maximum delay after which I will capture a reversal match is 25ms or 25 x 0.36 = 9 degrees. And this can vary as it is not synchronous with the timed loop.
I simply want to restrict this reversal error with +/- 2 degrees.
Any ideas ?
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(3,679 Views)
This thread continues here.
(3,668 Views)
I am not sure about the reason for  the re-direction. Maybe the idea was to avoid duplication of efforts and share the knowledge. Good. But   the question was more hardware oriented and reason why I had posted it  in this multifunction DAQ section with a copy of it in LV section.
Not sure if posting the same query in two different sections is a practice that is looked down upon within this forum. If so I am sorry.
Raghunathan
Raghunathan
(3,664 Views)
Hello Raghunathan,
We generally try to consolidate threads so that all the information is in one place which is why I posted the link to the other thread.  Please don't be too concerned.  Let us know if you have additional questions.
Laura
(3,654 Views)
Hi Laura,
I guessed as  much and thats fine by me. I only wanted to make sure that I don't  create an annoyance  by doing something that is frowned upon in a forum . Thanks for the clarification.
Regards
Raghunathan
Raghunathan
(3,646 Views)
