01-09-2012 12:54 PM
I'm new to labview and I am trying to acquire multiple voltages from several channels on a NI USB-6008 and display the signals continuously on separate charts. I am getting the charts to show up but it seems they are affecting one another because if I unplug one of the channels, the remaining graphs change as well. Any suggestions?
01-10-2012
01:48 PM
- last edited on
11-10-2025
12:44 PM
by
Content Cleaner
Hi Rachel8503,
From your description it sounds like you are experiencing what is called a "ghosting" effect in your measurements. This effect is described in this document, which also explains different methods to eliminate ghosting from your measurements. I would suggest you to try the options that this article mentions.
