Adlink ISA ACL8112PG replacement
in our old test equipment an Adlink Multi DAQ Card ACL8112PG is used. Now I would like to switch to NI hardware and LabView. Does anybody know if there is direct replacement for this card?
Here is the used pinout: (see attached files)
All 3 connectors are used.
Thank you in advance.
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(3,348 Views)
Accepted by topic author EWiebe
Hello EWiebe,
there is no direct replacement, if you need all DIO with TTL logic lines the the PCIe-6323 could be an option.
best regards
Alexander
(3,328 Views)
