Multifunction DAQ
Adquisicion de datos
I have a data adquisicion sistem. Is a NI PXi 8176 with a data adquisicion card, the NI PXi 6025E. I communicate with it trought a ethernet with a host computer. The software MAX have detected the devices but I can not see the chanels. The DAQ assistant don't find the chanels . I need help¡¡¡
(2,433 Views)
On which computer do you not see the channels? Which version of NI-DAQ are you using? Do you already have virtual or DAQmx channels configured on the remote computer and are expecting to see them on the host computer. Are you using LabVIEW RT?
Si quieres, puedes responderme en espanol. Tambien, podemos continuar esta conversacion por ni.com/ask.
Erin
(2,433 Views)
