Amplify Output Signal of NI9265, 960mW@600Ω
We want to amplify the output current of our DAC in order to drive the phase shifters on the TripleX chip. Output specifications of the currently used DACs (current modules):
https://www.ni.com/docs/de-DE/bundle/ni-9265-specs/page/specs.html
https://www.ni.com/de-de/shop/model/ni-9265.html
fmax = 100 kHz (max sampling freq. Of DAC)
Umax = 12 V
Imax = 20 mA
  • Pmax = 240 mW
Desired output after the current amplifier:
fmax = 150 kHz (50 kHz safety)
RL = 600 Ohm (load resistance)
Umax > 25 V
Imax > 40 mA
  • Pmax = 960 mW (@600 Ohm)
I was thinking to use an OPAMP
https://www.ti.com/amplifier-circuit/op-amps/power/overview.html
Does someone know wich one will fit the best?
Cheers rza
(1,135 Views)
if output should be +- 25V : https://www.ti.com/lit/gpn/opa454
SE : https://www.analog.com/media/en/technical-documentation/data-sheets/AD8510_8512_8513.pdf
didn't check the lead time 😉
Greetings from Germany
Henrik
LV since v3.1
(1,093 Views)
Hi Henrik,
thanks a lot!
Greetings from Germany to Germany 😉
(1,084 Views)
