An application calls a VI by reference with DAQ functions inside does not work?!
An application (appl.exe) calls a VI by reference. This VI includes DAQ functions, and that is the reason why it does not work! What can I do?
I do not want any solutions like "add dynamically VIs" in appl builder or why building an exe because it works fine in the VI. That doesn't help me.
Merry Christmas and a happy new year
Michael
(2,656 Views)
Does the app work on your development machine or does it only fail on a new pc? If it's only on a new one, did you install NI-DAQ there? Do the DAQ functions require settings in MAX for channels or scales? You say that you don't want a solution like "add dynamic VIs". Does that you mean that you did add them when you built the exe?
(2,645 Views)
