Analog I/O not working on the USB-6009
I have just started testing a NI USB-6009 device. I have installed MAX version 4.6.2f1 og both a windows 7 and XP machine. The 6009 device is detected and the driver properly installed as far as i know on both machines. When i start test panels i can correcly set and read all the digital in and outputs. On the analog side i can try to set a output voltage of anywhere between 0 and 5V but all i can measure on the ouput is 0,03V.
On the analog inputs the voltage reading is -10,3 volts on all the channels, regardless of choosing RTE or differential coupling. I have tried a direct coupling from AO to AI with the same results.
The DC voltage on port 30 is 0. Which should be 2,5V ?
Is the device defective? Firmwareproblems?
Any help is greatly appreciated.
Message 1 of 1
(2,939 Views)
