Analog Output Offset-USB6211
I just upgraded my desktop from Win10Home to Win10Pro.  Now when i plug in my USB6211 there is an unwanted offset voltage of about +20mv on the AO1 and AO0  pins.  This offset is still present when outputting DC or AC signals.   I have tried several version of DAQmx(15.5.1, 16.1, 18.6) with the same results.  I have an identical computer running Win10Home and a laptop running Win8 that do not present this problem.  I also have a USB6366 where this does not occur at all on any of the systems.  Has anybody ever encountered this before?
(2,589 Views)
Hi Brandon,
Have you done any troubleshooting? I found this KB that could help you.
You could also fix this programmatically, like it is said on this other KB.
Regards.
(2,564 Views)
