Analog Triangle USB-6008
I'm sorry if this question has been answere before, but I couldn't seem to find the solution to my problem.
I realized that there is a tutorial at https://forums.ni.com/t5/Example-Code/Continuous-Software-Timed-Analog-Output-for-the-USB-6008-and-U... on generating "Continuous Software Timed Analog Output for the USB-6008", but it only generates sine wave.
Is it possible to generate triangle wave instead?
Everything else is the same.
Thanks.
Message 1 of 1
(3,199 Views)
