Analog Waveform Generation - PCI 6115
I have no previous experience with labview, but i have been asked to do the following:
Use Labview to control the NI PCI 6115 board to generate 2 analog output waveforms.
I would appreciate any guidanance.
Thanks!
(3,576 Views)
(3,563 Views)
If you prefer a pratical hands-on learning approach, I'd suggest you take the Basics 1 and 2 course, and the Data Acquisition and Signal Conditioning Course, both run by NI.
http://www.ni.com/training/
(3,558 Views)
Hello tamermoh,
We also have a number of templates for basic DAQmx in the example finder.  You can browse to them under Hardware Input and Output»DAQmx»Analog Output. Hope this helps!
ColeR
Field Engineer
(3,542 Views)
