Analog capture with multiple digital trigger
We are using NI DAQ USB-6341 to achieve re-triggerable capture of 10 analog way, each with its own digital trigger input. Is it possible to have multiple triggered acquisition running at the same time (with different trigger) ?
(4,473 Views)
Hi nicolasp,
it is not possible to set multiple hardware triggers for different analog inputs, but you can do it by software.
You have to capture your analog and digital inputs and synchronize them.
On this page you can see how to synchronize multiple acquisitions:
M Series Synchronization with LabVIEW and NI-DAQmx - National Instruments
https://www.ni.com/en/support/documentation/supplemental/21/m-series-synchronization-with-labview-an...
Andi
(4,433 Views)
