Analog output not zero
Hello all,
I have a NI DAQ mx 6343 USB x series. A analog pump is connected to the analog output A0 (pin  15).
I see (measure with a volt-meter)  when i turn on the DAQ that the output goes to 1.35 volt and then to zero.
I havent started any software yet. The problem is that the connected pump starts running for a short period
until the output value is zero again.
Is this normal and how can i prevent this.
Regards
 Herbert Veldhuis
(2,102 Views)
Accepted by topic author VeH
Yes, it is expected as stated in the specifications and the duration is variable based on your system.
You could add a relay controlled by a DO line that will connect the signal to AO only when you run your automation and when DO/Relay is off, connect the Analog pump signal to GND.
Santhosh
Soliton Technologies
(2,047 Views)
Hi, thank you.
Thats a typical RTFM, but anyway now i know how to handle it.
(2,032 Views)
