Analog signal generation
I have posted a message a few days ago but there was no reply so I decided to ask once again for a help. I want to generate analog voltage signals (using USB-6259 device and native C) with the possibility of changing the data output buffer to achieve signal output change. Is it possible to do?
Generation is not a problem, but once the task is started the buffer change doesn't have any impact on signal.
Best regads,
Dariusz
Message 1 of 1
(2,801 Views)
