Analog start trigger with digital output task
Hi All!
My system - LabVIEW 8.5, PXI-6251.
I have to output sychronously 2 analog channels and 7 digital. For this purpose i use two tasks one analog and second digital.
Now to the question.
I need to start output on some level of signal wired to APFI0. So i guess that analog start trigger is good idea to use.
How can i control digital output task according to analog start trigger behavior?
Thanks in advance
Izia Elman
(3,604 Views)
Hello Izia,
Thank you for posting to the NI forums. It sounds like you want to use a PFI line to trigger an analog acquisition. In order to synchronize output, we need to share a time base and a start task. There are many examples in LabVIEW (Help>>Find Examples>>Hardware Input/Output>>DAQmx>>Synchronization>>Multi-Function) that can assist you. By clicking on anyone of these examples, you can view a description of it on the right side of the scree. If I am not understanding what you are trying to do, please clarify. Hope this helps!
Margaret Barrett
Digital Multimeters and LCR Meters
(3,582 Views)
