Any way to read value written by DAQmxWriteAnalogScalarF64
Is there any way I can read back from DAQmx the value written by DAQmxWriteAnalogScalarF64 function?
Thank you,
-Ilya.
(3,118 Views)
Hello llya,
To better answer your question, are you simply trying to perform an AI read?
Ali M
www.ni.com/support
(3,092 Views)
Hi Ali:
No, I'm trying to obtain the value that was previously sent to DAQmxWriteAnalogScalarF64 without resorting to caching.
I guess this will be the only option.
-Ilya.
(3,087 Views)
Hello llya,
Thats correct, the values would need to be cached.
Ali M
www.ni.com/support
(3,064 Views)
