Any way to use Labview 7 with DAQCARD-700
I would really like to be able to use my DAQCARD-700 with Labview 7.1. I saw that the only supported driver for this card was 6.9.3 used with labview 6.1. But I was hoping that someone out there may have found a patch or a work around so they could use Labview 7.1. If anyone has any ideas it would be greatly appreciated. It seems to me all you need is the correct DAQ VI's that you use in 6.1 to instal in 7.1
(2,937 Views)
There is a way to use older versions of NI-DAQ with LabVIEW 7.x.
-Alan A.
(2,932 Views)
