Arbitrary signal generation fron NI 9265
Hi, . I want to generate a pulse.I have written a program but there is some buffer error. I am attching the vi I have written. I am also attaching the signal that I want to get from NI 9265. I know I have to feed the signal to an amplifier for that. Thanks.
(3,262 Views)
I tried using a 9265 for this, it will not work correctly.  You should try, instead, using a Digital output card.  I am doing PWM now with a digital card and it works great.
Nathan - Certified LabVIEW Developer
(3,155 Views)
