Are part # pc-mio-16-e4 or scxi 1000 ch valid
When used with WinXP are there any compatability issues.
(2,378 Views)
Greetings,
Both the PCI-MIO-16E-4 and SCXI-1000 are fully compatible with Windows XP. The only thing you need to consider is the version of the NI-DAQ driver you are using. Version 6.9.2 was the first to be compatible with Windows XP. The current version is 6.9.3.
Good luck with your application.
Spencer S.
(2,378 Views)
