Assemblies not visible
Have installed 930f2 of software from NI but no other products.  Using C# in VS 2008.  NationalInstruments.Common is not visible as an assembly.  How do I get so I can referernce it?
Mark
(2,750 Views)
It sounds like you are using DAQmx 9.3.0f2. This is a run-time engine. If you want to install drivers for programming with DAQmx you need the full driver. Go to ni.com/support, click on NI-DAQmx, and then under "Drivers & Updates" you should see NI-DAQmx 9.4.
Colden
(2,736 Views)
