Assigning PFI lines to counter
Have anybody out there used "DAQmxSetCIFreqTerm" function on CVI before for PCI6221 DAQ card?
Hiren Patel
Message 11 of 27
(2,935 Views)
Ok, so ignore my previous post.  The second parameter is the channel name parameter that was used with the DAQmx Create Channel function.  If you left it blank, i.e. "", you can leave the second parameter blank.  The third parameter is the PFI line that you want to route the signal to.  You will need to use syntax like "/Dev1/PFIx".  Sorry about the confusion.
-Alan A.
Message 12 of 27
(2,926 Views)
Alan,
Thanks for the input. I have tried this but it still do not want to work. Here is my function I am trying to use, look at it and tell me what I am doing worng here.
int readFrequency(short sample)
 int32 sampleRead,
    samples;
 float64 freqRead[1024],
     freqReadAve;
 int i;
 freqReadAve = 0.0;
 samples = (int32) sample;
 DAQmxCreateTask ("", &freqTask);
 DAQmxCreateCIFreqChan (freqTask, "Dev1/ctr0", "", 2.0, 600000.0,
          DAQmx_Val_Hz, DAQmx_Val_Rising,
          DAQmx_Val_LowFreq1Ctr, 5, 4, "");
 DAQmxCfgImplicitTiming (freqTask, DAQmx_Val_FiniteSamps, samples);
/DAQmxSetCIFreqTerm(freqTask, "/Dev1/PFI8", "/Dev1/PFI8");
 DAQmxStartTask (freqTask);
 DAQmxReadCounterF64 (freqTask, samples, 2.0, freqRead, 1024, &sampleRead, 0);
 DAQmxStopTask (freqTask);
 DAQmxClearTask (freqTask);
 for(i = 0; i < sampleRead; i++)
  freqReadAve += freqRead[i];
 measuredFreq = (double)freqReadAve / --i;
 return 0;
Hiren Patel
Message 13 of 27
(2,922 Views)
Alan,
 int32 sampleRead,
     samples;
     freqReadAve;
 int i;
 freqReadAve = 0.0;
 return 0;
Hiren Patel
Message 14 of 27
(2,922 Views)
Alan,
 int32 sampleRead,
      samples;
     freqReadAve;
 int i;
 freqReadAve = 0.0;
 return 0;
Hiren Patel
Message 15 of 27
(2,923 Views)
Alan,
 int32 sampleRead,
       samples;
     freqReadAve;
 int i;
 freqReadAve = 0.0;
 return 0;
Hiren Patel
Message 16 of 27
(2,923 Views)
Alan,
 int32 sampleRead,
        samples;
     freqReadAve;
 int i;
 freqReadAve = 0.0;
 return 0;
Hiren Patel
Message 17 of 27
(2,923 Views)
Alan,
 int32 sampleRead,
         samples;
     freqReadAve;
 int i;
 freqReadAve = 0.0;
 return 0;
Hiren Patel
Message 18 of 27
(2,923 Views)
Alan,
 int32 sampleRead,
          samples;
     freqReadAve;
 int i;
 freqReadAve = 0.0;
 return 0;
Hiren Patel
Message 19 of 27
(2,923 Views)
Sorry I hit the TAB to many times
Hiren Patel
Message 20 of 27
(2,924 Views)
