Attempting to Recompile Kernel with DAQ Software
Sorry if this is the wrong place to ask this, but I don't see anywhere that would be more appropriate.
I'm running NI-DAQmx Base 15.0.0 on Scientific Linux 6.X with Kernel version
3.0.80-rt108. However, I discovered that we left out a couple of kernel features when compiling the kernel the first time so I'm wanting to reconfigure and rebuild my kernel.
However, when I attempt to re-build and install my kernel the last step (make install) breaks with the following lines:
[root@<machine name> linux-3.0.80]# make install
sh /root/linux_source/linux-3.0.80/arch/x86/boot/install.sh 3.0.80-rt108-7-28-27 arch/x86/boot/bzImage \
System.map "/boot"
ERROR: modinfo: could not find module nimxdfk
ERROR: modinfo: could not find module nipxirmk
ERROR: modinfo: could not find module nidimk
ERROR: modinfo: could not find module nimdbgk
ERROR: modinfo: could not find module niorbk
ERROR: modinfo: could not find module nipalk
ERROR: modinfo: could not find module nikal
It appears that when I rebuilt the kernel and modules the NI modules were not included. Does anyone know how to either add them to the path to get installed by "make modules_install"? Would uninstalling the drivers and reinstalling after i upgrade the kernel be best?
James
(3,723 Views)
Accepted by topic author james.orr
The Errors didn't actually break the installation. I was just letting me know it couldn't re-compile those modules for the new kernel in that compile (since I don't have source code). I re-installed with the new kernel and everything is good.
(3,676 Views)
