Average signal level
I am working with labview software for analysing the data resulted from Piezo electric transducer using DAQ PCI-4452. I would like to know how to record the Averaga Signal Level. I could not find any VI (program) for fetting the data related to Average Signal Level (ASL). Can you send me a  VI, thank you.
Nishant
(3,393 Views)
So you just wanted to carry out averaging on the data? Post your VI here and I'll show you how to fit this analysis into the code.
Stuart
(3,363 Views)
A simple way to do this would be to continue adding the current signal (assuming you're in a loop reading signal levels) to the previous ones, and divide by the iteration the loop is on.
(3,361 Views)
