BNC 2110 connection to PXI-6143
Sir
I am using a PXI based DAQ system. The card installed on a DAQ system is NI PXI-6143 (S Series card). I have connected a BNC 2110 card to PXI-6143 card by PXI-PXI cable. In BNC 2110 card I wish to use digital trigger line from the digital and Timing I/O connector. I am connecting the trigger cable to PFI 1 and D GND. In my program when I run the program it is showing an error message: NO  registered lines could be found between the devices in the route.Moreover in NI-MAX the configuration tree is not showing BNC 2110. The configuration tree is only showing NI-PXI-4462(Dev1) and NI-PXI 6143(Dev2). I need your help. If BNC 2110 needs to be added manually in NIMAX  please tell me the steps.
With regards!!!
Udai Giri Pratap
(4,094 Views)
It looks like the BNC-2110 is all passive so there is no way for the system to know that you are interfacing with that or your home made  interface.
(4,083 Views)
