BNC 6251 Battery Pack?
Hi, I need to power my BNC 6251 remotely with a battery pack, any suggestions on what batteries to use or packs?  NI makes a battery pack but it says it is for the E-series, can that be used for the M-series as well?
thanks
Chris
(3,249 Views)
Hi Chris,
      The power requirement can be found in the specifications. You'll need 11-30V,the batterypack does 12V.  Have a good one!
(3,237 Views)
Greetings!
I would recommend any standard battery pack, based on AA or D type rechargable batteries.
All they need is to provide the required current/voltage output.
There are several of them on the market.
Please let us know if you have any additional questions!
- Nathan
USB power supply requirements .... 11 to 30 VDC, 20 W,
locking or non-locking
power jack with 0.080”
diameter center pin,
5/16–32 thread for
locking collars
(3,208 Views)
