BNC connectivity for USB 6009
Hello all,
I have a question about connectivity to the USB 6009. I have a current probe that has a male BNC connector. How do I connect/adapt this to connect to the USB 6009? Many suggested this: getting a female BNC connector with a cable and cutting off the cable to connect to 6009.
Is this a good way of doing this? Or are there other connectors/cables I can use without resorting to cutting cables?
G.Sibi
(4,054 Views)
I use animals such as these, no cutting required
http://www.alliedelec.com/Search/ProductDetail.asp?SKU=885-4969&MPN=4969&R=885%2D4969&sid=45D0FF804F...
(4,050 Views)
Wow, that is sweet. Thanks a ton, I have order the cable.
(4,044 Views)
Hi, could you tell me which cable you ordered?
(2,851 Views)
