Bad firmware with USB-6008 on lsdaq
I have already post this request on the french forum
I have a problem to use my USB-6008 on linux. I use Mandriva One 2007 ( 2007.0 )
I installed NIKAL16, NI-VISA-4.2.0 & nidaqmxbase-2.1.0. Installation looks fine.
When I run lsdaq, I have this message :
[francois@localhost National Instrument]$ lsdaq
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
NI-DAQmx Base has found a device with incompatible firmware.  You may need to reload the firmware on a machine with NI-DAQmx installed for the following device:
NI USB-6008
Serial Number: 012F42CB
I have not installed NI-DAQmx on my computer so this link is not sutable http://digital.ni.com/public.nsf/allkb/A3C7200E881696FA862570AD0050E8D0.
I have follow the procedure to switch firmware with a windows computer ( http://digital.ni.com/public.nsf/allkb/64BA7A1D64D3D5518625726D0066A780 ). First with Vista and daqmx 3, secondly on XP with daqmx base 2.1 without any change.
Here is the result of some fonctions :
[root@localhost francois]# lsmod | grep ni
nipxirmk              121780  1
nidimk                333024  2 nipxirmk
niorbk                 98100  2 nipxirmk,nidimk
nipalk               1131856  6 NiViPciK,nipxirmk,nidimk,niorbk
nikal                  59744  3 nipalk
usbcore               108160  7 nikal,usbmouse,ehci_hcd,usbkbd,usbhid,uhci_hcd
[root@localhost francois]# lsusb
Bus 005 Device 001: ID 0000:0000
Bus 001 Device 005: ID 413c:3200 Dell Computer Corp.
Bus 001 Device 004: ID 413c:2003 Dell Computer Corp.
Bus 001 Device 001: ID 0000:0000
Bus 004 Device 002: ID 3923:717a National Instruments Corp.
Bus 004 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
[root@localhost francois]# ls -l /dev/bus/usb/004/002
crw-rw-rw- 1 francois root 189, 385 déc  7 09:40 /dev/bus/usb/004/002
What can I try now ?
Thx
François
(3,316 Views)
My bad
I tried again with windows XP and a new downloaded driverselector.exe et lsdaq is now OK
(3,300 Views)
