Best equipment to use
I'm using a cDAQ-9174 and NI-9229 to record and log the current/voltage in 2 separate circuits on a test bench.  I've got a current shunt for the smaller circuit which only runs a few amps, but the second circuit can peak at over 70 Amps and I was wanting to use a LEM brand current transducer.  This is my first time working with these, has anyone else used them with NI equipment, and how easy/difficult are they to incorporate into the NI system?
Message 1 of 1
(2,695 Views)
