Best way to generate specific digital signal
I'm using the NI PCIe-6361 to sample analog data @ 2MHz as well as write to two DAC channels every N number of ADC samples. This process runs continuously until cancelled by a user. This is all working fantastically :). However, I now also need to write to a digital channel at a fixed interval (something like 3ms low then 11ms high) for as long as my process is running. What's the best way to do this? I know I could write a buffer of data to the a digital channel, but it seems to me that there must be a better way to get what I want using timers. Am I thinking wrong?
(3,626 Views)
Greetings Herbrandson
Have you considered using a Counter task for this? LabVIEW comes with some examples that might prove useful to you. The Counter (Buffered) - Continuous Output sounds like the right example to thet started. Otherwise, you could select a simple Counter - Continuous Output and play with the duty cycle.
Please tell us if you have any other question.
Regards.
Luis J.
(3,611 Views)
