Borland 6.0 Help
Hi Parikshit-
This KB has some info about using Borland C/Delphi with NI-DAQmx.  Please try the type libraries there and let us know if you're still having problems.
Thanks-
Tom W
Message 11 of 19
(2,124 Views)
Hi
I think NI has already created the Borland lib file but I can not find the link.
Do a search as it is on this forum.
Ta
Colin
Message 12 of 19
(2,114 Views)
Hey Colin-
See my post directly above yours.Smiley Wink
Tom W
Message 13 of 19
(2,110 Views)
i am trying to use the Turbo C to access the 6052 pci  card . is it possible by using the header nidaqmx.h and lib .if yes how to configure steps
thanks
haider
Message 14 of 19
(1,928 Views)
Hi Haiden
They might do but I seem to remember that object code was changed so it might not be compatable.
You must use the Borland version of the MX driver.
See above.
Colin
Message 15 of 19
(1,923 Views)
borland version of MX driver is a whole new software i have to add just a driver file?
Message 16 of 19
(1,899 Views)
Hi Haiden
I do not understand what you are saying.
>>i have to add just a driver file.
You need the Borland lib files for MX (there is a link to them in one of the other messages).
Add them to your project and add the include the MX header files.
Regards
Colin
Message 17 of 19
(1,894 Views)
hi
yes i included the mx header file
NIDAQmx.h and library file but still the borland comiler generates redefinition errors.
ok
Message 18 of 19
(1,894 Views)
Hi Haider,
This is an old thread and it looks like the questions you have about including the DAQmx header file with your Turbo C/C++ compiler are already being handled on another post.  Please refer to this Discussion Forum Thread for any other posts about this issue. Thank you!
Vanessa L.
Message 19 of 19
(1,879 Views)
