Buffer Underflow error(-200016)
I'm sorry. I miskate 3 posting. But I could not  know, How to erase these thread.
We control 3Analog Out channel on PCI-6229 using ANSI C.
When we increase Analog Output rate, then Buffer underflow error(-200016) is occurred.
But this upper limit rate is very different between SampleMode(FinitSamples and ContSamples)
   *The result of our evaluation
                         SampleMode Upper                 Rate[Ksample/sec]
                         DAQmx_Val_FiniteSamps          10
                         DAQmx_Val_ContSamps            more than 40
Is this Phenomenon Correct?
Is there any idea for increase upper limit using DAQmx_Val_FiniteSamps of SampleMode.
Sincerely,
(3,105 Views)
本メールの回答をお客様からの一番最初のメール(エラー -200016)と統一しますのでよろしくお願いいたします。
日本ナショナルインスツルメンツ株式会社
技術部 フェルナンド ニシャーンタ(Nishantha Fernando)
(3,069 Views)
