Buffer and half buffer sizes
Hi
I have a question regarding buffer size. I am working with a PCI-6025E board and NIDAQ functions to control it (v 6.9.1).
For E Series devices, SCAN_Start requires the total number of scans be at least 2. Does this follow for continuous reading mode too? (i.e., double buffering). Alternatively, what is the minimum number of scans a half buffer should cater?
Peter
(3,290 Views)
Peter,
In the NI-DAQ Help file for SCAN_Start, you can see that buffer must have a length equal to or greater than count. However, this may not be what you want to do. If your purpose is to read 2 channels once or 1 channel twice, then you should just use a single buffered scan.
Geneva L.
http://www.ni.com/support
(3,290 Views)
Hi Geneva L
Thanks for your reply.
I wish to read 2 channels every time an external trigger is received. The scanning is controlled externally DAQ_Config( , 0, 2 ) and am using Select_Signal( , ND_IN_SCAN_START, ND_PFI_0, ND_LOW_TO_HIGH ). Every time a scan is complete, I wish to perform some other operations, then issue a command to arm our equipment. Only on SCAN_Start command is issued to initiate the acquisition process.
So if I am double buffering, the half buffer size would contain 2 samples (1 scan), and the count in SCAN_Start would be 4 (for two scans), with buffer size 4. However I found DAQ_DB_Transfer returning with overwrite errors, which I should not see; on the other hand, I may have misunderstood.
Peter
(3,290 Views)
