Build Error: DAQmx.Task.Triggers.get cannot explicitly call
I am using Measurement Studio 7.0 and Visual Studio 2003 using C#. I get build errors such as: DAQmx.Task.Triggers.get cannot explicitly call operator or accessor.
(3,221 Views)
Are you using a shipping example when you get these errors, or is this code that you have written?  If it is your own code, try running a shipping example and see if it works fine.  The shipping examples are located in the following directory:
...»Program Files » National Instruments » MeasurementStudio70 » DotNET » Examples » DAQmx
-Christina
(3,189 Views)
