C#, NI Hardware, and Installers
I've been a LabVIEW developer for awhile now, and it is pretty clear that when I use NI's instrument drivers, runtime environment, etc... that the installers for that application can get pretty large.
If I developed a program in C# that uses NI Hardware will the installers still be large or will they be cut down significantly?
(2,537 Views)
Accepted by topic author zenthoef
Hello Zenthoef
Actually the Runtime Engines are the same. Let me attach just an example below.
http://www.ni.com/download/ni-visa-run-time-engine/6647/en/ (Run time Engineen)
http://download.ni.com/support/softlib//visa/NI-VISA/17.0/Windows/readme.html (Readme)
As you can see the Readme file has a list of Microsoft Visual Studio Support for the VisaNS .NET Class Library also, the VISA Studio Versions.
I hope that helps
Regards
(2,506 Views)
