C language to NI modules
Hi all,
I am using a cDAQ-9178, CompactDAQ chassis (8 slot USB) and associated IO modules to interface field devices. I want to use C language to develop a control program on a PC WITHOUT using Labview. Is this doable? If it is, do I need any driver/software installed on the PC to ibterface the I/O modules? I am using ethernet connection from my PC to the CompactDAQ chassis.
Thanks a lot.
(2,944 Views)
Of course you can use C. You got the DAQmx driver with your hardware and you had the option to install C support. Examples are included.
(2,935 Views)
