C++ program to read temperatures from NI cDAQmx-9191
I'm also not sure where the actual temperature readings from the thermocouple is stored in this program. The Read in the example looks like this:
int32       error=0;
    char        errBuff[2048]={'\0'};
    static int  totalRead=0;
    int32       read=0;
    float64     data[1000];
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,-1,10.0,DAQmx_Val_GroupByScanNumber,data,1000,&read,NULL));
    if( read>0 ) {
        printf("Acquired %d samples. Total %d\r",read,totalRead+=read);
        fflush(stdout);
Are the temperatures being stored in the data array? I tried printing the first element (data[0]) but it comes out as a very large number, I'm sure if this number is supposed to represent the temperature in some way.
Message 11 of 12
(1,853 Views)
Hi TimCast,
To verify if you are getting correct measurements, you can use NI MAX and create a task on it. The following link will show you how to do it.
http://www.ni.com/getting-started/set-up-hardware/data-acquisition/thermocouples
I also want to show you the article that can guide you a little more with Text Based DAQmx examples. In here, you should be able to select which Text Based Language you are using and understand better the coding for them.
http://www.ni.com/example/6999/en/
Luis C.
Message 12 of 12
(1,841 Views)
