C series module for ultrasonic transducer driver and receiver
Hi all,
I'd like to drive a small ultrasonic transducer and receive the signal from a second transducer ideally with a sine wave. We have some existing C series chassis and I was wondering if anyone can recommend a hardware solution that might be suitable. All suggestions very welcome.
Ed
(925 Views)
What is the model of your ultrasonic transducer.
https://tmesystems.net/
(895 Views)
The first link does not provide any datasheet and information on the output signal.
The second mentions that the output signal type is digital. I assume it is something similar to Ultrasonic Sensor HC-SR04 and Arduino
You would need DIO modules that can access onboard counters to send the trigger and capture the echo signal precisely. See cDAQ Module Support for Accessing On-board Counters.
(873 Views)
@edwaugh_cloudcycle wrote:
Hi all,
Ed
What are you trying to achieve with these ultrasonic transducers and cDAQ?
Driving/receiving directly from a just a ultrasonic transducer is a specially as it involves special circuit to drive at high frequency.
Santhosh
Soliton Technologies
(869 Views)
