C series module will not pop up in configuration tree cDAQ-9171
On the NI-Max program i can not get the C series module to pop up on the configuration tree under "devices and interfaces". It says its supose to do it automatically but it wont popup. I have a cDAQ-9171 chassis and a NI 9215 module. Im trying to get a reading on its inputs so I then can set it up on the xy plotter program. I have a amber light on the ready led and active is off but will flash green for a split second when you self test it under the chassis on the configuration tree.
(4,212 Views)
Hi dhpt99,
Is this guide below the one you have been refering to?
http://www.ni.com/getting-started/set-up-hardware/data-acquisition/compactdaq
You should be able to configure everything to be recognized using this guide. Please right click the chassis and post a screenshot of what options are shown.
(4,171 Views)
