CANOPEN For single board RIO
Is there any support library for CANOPEN applied on single board RIO sbRIO9636?
Thanks.
(3,611 Views)
I have the same question concerning the sbRIO 9606.
There are some tutorials for cRIO using FPGA, but is it possible to translate the known PDOs or SDOs to the format which can be than used with Embeded CAN for sbRIO?
Thank you in advance for any comment!
(3,539 Views)
Hi, this is not the correct board to place this question. I strongly recommend using the Industrial Communications board instead.
Good day
Alejandro C. | National Instruments
(3,322 Views)
