CDAQ NI 9239: external 100 kHz timebase
Hi everybody,
I'm using several NI 9239 modules on a NI CompactDAQ 9174 chassis. Due to the specifications of the Delta-Sigma digitizers, the minimum rate for a 12.8 Mhz timebase is 1613 Hz. For the hardware configuration used (NI-9174 + NI-9239), is available a slower timebase (for example 100 kHz timebase) to apply in the 9239 module different from the 12,8 MHz internal timebase and the 20 MHz and 80 MHz timebases?
Thanks in advance.
Regards.
Message 1 of 1
(3,326 Views)
