CDAQ chassis and 9266
Hi
I have procured CDAQ 9189 and 9266 AO modules. 9266 is detected and self test is OK. It is allowing to write to the module from test panel also, but no output is visible at the 9266 terminal. what might be the issue.
(1,180 Views)
That module outputs current, not voltage, and requires an external power supply, have you read the manual and wired up the external supply?
-AK2DM
(1,150 Views)
Thanks for the reply. Yes I was missing the external supply. It is resolved.
(1,134 Views)
