CDaq-9188 Max configuration and reset issues.
I have an old Cdaq-9188 chassis that is exhibiting peculiar behavior. When I try to configure it in MAX, most options ask me to log in as a user with permission. I try admin:no password to log in, however I always get a message:
"Could not connect to the log-in service. Make sure the target is turned on, connected to the network and not in safe mode."
I have tried factory resetting the device multiple times without any success. Strangely, when I use the "set permissions" button to configure the device through the web interface, all functionality works, including logging in.
(2,871 Views)
Hello parsec43,
To factory rest the device did you hold the reset button of the device for over 5 seconds, until the STATUS LED lights up?
__________________________________________
The best way to thank, is to give KUDOS
(2,666 Views)
