CNiReportData instance is in an unusable state
I am using WinGeo software from Olson instruments When I need to print the data Error message says CNiReportData instance is in an unusable state Any help ? I am using Olson FDPC (WinXP)
Currently installed Ni-DAQmx 8.9.5
Regards
Fadi
(3,364 Views)
Hi Fadi,
Are you receiving this error within WinGeo? If so, I would recommend contacting Olson instruments for specific support on the error message. http://www.olsoninstruments.com/software.php.
MJ
Application Engineer
(3,328 Views)
