CRIO and Interface Cards Suggestion for SPI/I2C, RS232, RS422 and RS485 Communication
NI provides libraries for I2C and SPI and use the DIO cards - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019VSSSA2&l=en-US
You can use 9871 for RS422/485 and 9870 for RS232
Santhosh
Soliton Technologies
(878 Views)
Hi Santhosh,
Thank you for your recommendation. What about the CRIO? which one should I use?
(856 Views)
There are a few options for chassis and controllers, you need to choose one based on your application need. If all that you need is to gather data from SPI/I2C, RS422/485, RS232, you don't need a cRIO at all.
cRIO is used for time-critical applications.
Santhosh
(851 Views)
