10-28-2006 07:23 PM
10-30-2006
03:19 AM
- last edited on
07-11-2025
09:39 AM
by
Content Cleaner
Installing relevant device Drivers should show your Device on MAX.
First install CVI and relevant hardware, swithch off system and then insert your card to the availible PCI slot. When you switch on your system, MAX should automatically detect your card in relevant Devices folder
Since this card is supported by both versions, see if reinstalling the latest supported version of Traditional DAQ drivers or DAQmx Drivers will do the job
( Note: you can install both versions but take care that you do not use/call both versions for same device in an application program )
10-30-2006 11:35 AM
