CWAI not seeing DAQPad6020E in Vista
My client upgraded the computer attached to my Data Acquisition device from Windows XP to Windows Vista. The MAX can see the device (DAQPad 6020E) and read the Analog channels but when I start my application, it is not seeing the device. The applicaiton was built in Delphi and uses the CWAI ActiveX component. Does anybody know if my problem is Vista or is it just a configuration issue based on the fact that MAX can see the device but my application cannot?
Keith
(2,791 Views)
Hi Keith,
Did this same program work just fine on XP? How can you tell the application is not seeing the device? Are you getting an error? Thanks for the info.
(2,752 Views)
