CWDAQ in VB 2010
Since you are not running your TDAQ based application concurrently with your new application, I would still recommend using DAQmx.
http://zone.ni.com/devzone/cda/tut/p/id/4344
If you must use TDAQ, you will need to develop a TDAQ application in VB or Labview (from examples) and compile them as DLLs. Once you have your DLLs, you can call them from your .Net application.
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
Message 11 of 12
(868 Views)
I use this code it works.
Dim ReadingVoltage
With AxCWAIPoint
   .Device = 1
   .SingleRead(ReadingVoltage)
End With
UserInterfaceTextBox.Text = UserInterfaceTextBox.Text & CStr(ReadingVoltage) & vbNewLine
Thank you,
Good NI
Message 12 of 12
(855 Views)
