CWDI gives error with 6024E
we are programming with an application of Measurement Studio (Visual Basic v6), using CWDI in a Waveform Digital adquisition and everytime we use this Active X (CWDI) occurs the same ERROR: runtime error 10007(VB program stops in cwdi1.configure)any ideas? thx
(2,514 Views)
Greetings,
When using the NI 6024E for digital operations, you should use the CWDIO control. Since the NI 6024E only supports static (software-timed) digital I/O operations, CWDI and CWDO cannot be used. You should examine the Digital Input Example available in the following location:
C:\Program Files\National Instruments\MeasurementStudio\VB\Samples\DAQ\Digital\Digital Input
Good luck with your application.
Spencer S.
(2,514 Views)
