Cable connector screw size
What is the screw size on the connectors of the SH68-68-D1 and SH68-68EP/M type cables?
(3,515 Views)
Accepted by topic author IGRG
Hi IGRG,
Here's an engineering drawing showing the screw size (2-56 UNC-2A).  The cables that you mentioned use the same screws.  Dimensions are in inches and [millimeters]:
I hope that helps!
Best Regards,
John Passiak
(3,508 Views)
