Calibrating SCXI-1520
I am looking to calibrate a SCXI-1520 myself. I have found a lot of posts that refer to NI MAX and using the calibration tool on there. Can this be done through a program in LabView? Any documentation I have found about this device is out dated or points to web pages that no longer exist. Because of this, creating a new code has been a bit of a challenge.
I have explored the DAQmx calibration VIs that are on LabView, but I am not entirely sure what components I need in my code, or if it will even work the way I want it to.
(3,282 Views)
I was wondering if you've had the chance to view this tutorial regarding external calibrations with the SCXI: http://www.ni.com/tutorial/4845/en/ .
Marco Chanchu
Applications Engineer | National Instruments
Marco C.
Applications Engineering
(3,251 Views)
I did look at that. It helped me to some extent, but is still feel unsure of what I actually need to include in my code
(3,248 Views)
I believe that as long as the VI's from the graphic are used in the order specified, you should be able to perform the calibration on your SCXI. A loop would also need to be used to cycle through the different calibration values depending on your hardware's specifications.
Marco C.
(3,239 Views)
