Calibration system USB6001
Good evening everyone ,
I am working on a project in python to acquire an analog signal output from inverter  to  analog input of USB6001. the problem is when I acquire an analog input in voltage every minute, I have a random values ​​(-5V , -0.1V , 4V), in the same time my inverter is off normaly the value 0V should be displayed every minutes.
Thank you in advance
(1,420 Views)
Please share the exact schematic of connections and the code you use to capture the data.
Santhosh
Soliton Technologies
(1,393 Views)
